Print at Oct 3, 2026, 1:14:31 AM
Posted by salva.segui at Apr 12, 2012, 7:41:42 PM
photography level 3 and 4 problems
Hello to everybody,
If I create a photography at level 3 or 4 I get a result full of shadows around the building (floor grey/dark)and a very bad resolution, during the process of the project I work step by step saving every couple of hours my work on diferent files.
Starting a new project from cero I don´t have this problem but after some modifications the problem appers and then is thear for always.
Any idea??
Posted by Puybaret at Apr 12, 2012, 8:44:12 PM
Re: photography level 3 and 4 problems
The shadows are different in aerial view mode and virtual visit mode. This was programmed this way because of a bad rendering effect in some cases.
Posted by salva.segui at Apr 13, 2012, 11:02:26 AM
Thanks for your answer Mr. Puybaret
Sorry, I have not been clear with my explanation,then...
You know how can I add a picture of the problem on this post for show you better the problem?
Thanks
Posted by salva.segui at Apr 13, 2012, 11:04:45 AM
photography
Posted by salva.segui at Apr 13, 2012, 11:15:10 AM
Posted by salva.segui at Apr 13, 2012, 11:19:02 AM
I'm sorry, I'm try to add a photo for show you the problem but I can not, can I send you it by e-mail?
Thanks
Posted by Puybaret at Apr 13, 2012, 1:42:23 PM
Please have a look to this subject to help you add a photo to a message.
Posted by salva.segui at Apr 13, 2012, 3:08:40 PM
Here you have¡¡
Thanks a lot
Posted by salva.segui at Apr 13, 2012, 3:16:28 PM
There you can see that the 3D view is a clean view without shadows.On the photagraphy, you can see how are the floor shadows and strange figures never I designed or planned.
Posted by Puybaret at Apr 13, 2012, 7:07:37 PM
This may happen if the building is very very very large.
Can you check the size of your plan? From the image you posted it shouldn't be larger than 100 meter long, and the effect you reported should happen if it's larger than 500 meter.
If you work with imperial system, maybe you mixed feet and inches.
