Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: photography level 3 and 4 problems |
| Print at Sep 30, 2026, 4:06:27 AM | |
| Posted by salva.segui at Apr 12, 2012, 7:41:42 PM |
photography level 3 and 4 problems Hello to everybody, If I create a photography at level 3 or 4 I get a result full of shadows around the building (floor grey/dark)and a very bad resolution, during the process of the project I work step by step saving every couple of hours my work on diferent files. Starting a new project from cero I don´t have this problem but after some modifications the problem appers and then is thear for always. Any idea?? ![]() |
| Posted by Puybaret at Apr 12, 2012, 8:44:12 PM |
Re: photography level 3 and 4 problems The shadows are different in aerial view mode and virtual visit mode. This was programmed this way because of a bad rendering effect in some cases. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by salva.segui at Apr 13, 2012, 11:02:26 AM |
Re: photography level 3 and 4 problems Thanks for your answer Mr. Puybaret Sorry, I have not been clear with my explanation,then... You know how can I add a picture of the problem on this post for show you better the problem? Thanks |
| Posted by salva.segui at Apr 13, 2012, 11:04:45 AM |
Re: photography level 3 and 4 problems photography |
| Posted by salva.segui at Apr 13, 2012, 11:15:10 AM |
Re: photography level 3 and 4 problems |
| Posted by salva.segui at Apr 13, 2012, 11:19:02 AM |
Re: photography level 3 and 4 problems I'm sorry, I'm try to add a photo for show you the problem but I can not, can I send you it by e-mail? Thanks |
| Posted by Puybaret at Apr 13, 2012, 1:42:23 PM |
Re: photography level 3 and 4 problems Please have a look to this subject to help you add a photo to a message. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by salva.segui at Apr 13, 2012, 3:08:40 PM |
Re: photography level 3 and 4 problems Here you have¡¡ Thanks a lot ![]() |
| Posted by salva.segui at Apr 13, 2012, 3:16:28 PM |
Re: photography level 3 and 4 problems There you can see that the 3D view is a clean view without shadows.On the photagraphy, you can see how are the floor shadows and strange figures never I designed or planned. |
| Posted by Puybaret at Apr 13, 2012, 7:07:37 PM |
Re: photography level 3 and 4 problems This may happen if the building is very very very large. Can you check the size of your plan? From the image you posted it shouldn't be larger than 100 meter long, and the effect you reported should happen if it's larger than 500 meter. If you work with imperial system, maybe you mixed feet and inches. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by salva.segui at Apr 20, 2012, 8:37:42 AM |
Re: photography level 3 and 4 problems Thank you very much, you're right, I made a mistake between "mm" and "cm". Now the result is perfect. Thanks again. |
Current timezone is GMT Sep 30, 2026, 4:06:27 AM |
