Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: When walls are meeting, how can I record/show an angle as a diminsion |
| Print at Oct 15, 2026, 10:14:27 AM | |
| Posted by johncros at May 14, 2012, 2:30:21 AM |
When walls are meeting, how can I record/show an angle as a diminsion First, let me say that I think this product is GREAT and generally very easy to use. I am having a problem with one thing though. When I have walls or other components that do not meet at right angles, I cannot find any way to display the suitable angle on the floor plan. I have not been able to find any mention of angular dimension arcs or anything like it in the help. When I draw the adjoining wall, SD3D does a very good job of showing me the vector angle but I cannot get the angle measurement notation to persist. Is there something that I doing wrong or that I missed? Thanks John |
| Posted by Puybaret at May 14, 2012, 6:43:50 AM |
Re: When walls are meeting, how can I record/show an angle as a diminsion Angle dimensions don't exist in the current version. The angles are shown only while drawing between walls bounded to each other. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by chrispy1970 at Jun 2, 2012, 2:26:33 AM |
Re: When walls are meeting, how can I record/show an angle as a diminsionThere´s a reason for this problem. double click at the wall you ´ll cange the angle. then you must change the start or endpiont x and y koordinates. if you need an specified angle like 10° you ´ve to calculate it manually. Math is your friend. greetz chrispy |
Current timezone is GMT Oct 15, 2026, 10:14:27 AM |
