Print at Sep 26, 2026, 12:54:06 AM
Posted by Lynn22 at May 23, 2012, 1:46:12 PM
Doors not punching holes
Hi everybody, I'm new to the forum but not new to Sweet Home which I discovered several years ago and may I congratulate the developer since the program has really 'matured' over the years.
Getting back into building interiors I've ran into a snag. I downloaded the models listed below but when I place them in my building - with magnetism turned on - they will only snap to the outside (inner or outer) of a wall. When I turn magnetism off then I can place them in the wall but they don't create the 'hole' they should fit in.
Is there any setting that I am missing to make this work ?
Many thanks for any help I can get
Sliding French doors http://www.sweethome3d.com/models/contributions/frenchDoors.zip
Darker front door http://www.sweethome3d.com/models/contributions/frontDoorDark.zip
Door http://www.sweethome3d.com/models/contributions/door1.zip
Exterior door http://www.sweethome3d.com/models/katorlegaz/exterior-door-07.zip
Posted by beber_mal at May 23, 2012, 3:02:33 PM
Re: Doors not punching holes
have you check the option "door or window" in the furniture import wizard?
Posted by Lynn22 at May 23, 2012, 5:23:28 PM
Thank you very much beber_mal that was the setting that I missed.
All is working fine now
