Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Changing shortcuts |
| Print at Oct 14, 2026, 10:38:11 PM | |
| Posted by vkaci at May 29, 2012, 8:46:46 AM |
Changing shortcuts Hi, Does anybody knows, how can I change the shorcuts? It sounds very good that the selection shortcuts ends with the first letter of functions like ctrl+shift+w for wall and r for room, but in this case both hands needed to press it, which is wery unconfortable because I need to release the mouse. So I would like to change some, but I do not know how. Thanks for the help. |
| Posted by Puybaret at May 29, 2012, 9:44:06 AM |
Re: Changing shortcuts Unless you're a programmer able to update the program, it's not possible at this time. There will be probably a pane in preferences able to configure shortcuts. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by vkaci at May 29, 2012, 3:57:23 PM |
Re: Changing shortcuts Thanks, I have already downloaded the source and I tryed to find the relevant code but it is so big and I only exeperince width Java is the android ecosystem... |
| Posted by Puybaret at May 29, 2012, 5:30:59 PM |
Re: Changing shortcuts It's not in Java code, but in the src/com/eteks/sweethome3d/swing/package.properties resources file. Simply change the values of the keys named AcceleratorKey. Good luck! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 14, 2026, 10:38:11 PM |
