Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Floors and rooms and floor plan image |
| Print at Oct 2, 2026, 11:15:57 PM | |
| Posted by stevegalante at Jun 18, 2012, 12:21:14 AM |
Floors and rooms and floor plan image I drew some walls of a room without actually drawing a room, but since I needed to put a floor I had to draw a room with the same dimension of the walls, so in other words if you do not draw a room you cannot add a floor, right ? And one other thing, maybe it's me but, how do you create an image file (*.png, .jpg, ecc.) of the floor plan (not the 3d rendering) ? Thank you, still newbie here... ![]() ---------------------------------------- www.stevegalante.com |
| Posted by Puybaret at Jun 18, 2012, 7:10:03 AM |
Re: Floors and rooms and floor plan image if you do not draw a room you cannot add a floor, right ? Yes. Automatic floor generation may appear in a future version, but if it could be handy in many cases, I fear it could get worse for special cases like mezzanine, multiple floor in a room...how do you create an image file (*.png, .jpg, ecc.) of the floor plan You can export the plan at SVG format with the Plan > Export to SVG format menu item, and you can get a bitmap image of the selected plan items with a copy/paste in any image or word processing software (this second solution might not work under Linux).---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stevegalante at Jun 18, 2012, 4:52:31 PM |
Re: Floors and rooms and floor plan image if you do not draw a room you cannot add a floor, right ? Yes. Automatic floor generation may appear in a future version, but if it could be handy in many cases, I fear it could get worse for special cases like mezzanine, multiple floor in a room...Thank you, is it possible to delete the area measurement that appears when you draw a room ? how do you create an image file (*.png, .jpg, ecc.) of the floor plan You can export the plan at SVG format with the Plan > Export to SVG format menu item, and you can get a bitmap image of the selected plan items with a copy/paste in any image or word processing software (this second solution might not work under Linux).Thank you, it would be nice to have a simple save as image file though. ---------------------------------------- www.stevegalante.com |
| Posted by Puybaret at Jun 18, 2012, 5:25:27 PM |
Re: Floors and rooms and floor plan image is it possible to delete the area measurement that appears when you draw a room ? Uncheck the Display area check box in its modification pane.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stevegalante at Jun 18, 2012, 6:52:04 PM |
Re: Floors and rooms and floor plan image 'ppreciated ! ---------------------------------------- www.stevegalante.com |
Current timezone is GMT Oct 2, 2026, 11:15:57 PM |
