Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Version 3.5 - Old data build up issue |
| Print at Sep 29, 2026, 8:41:20 AM | |
| Posted by ndhduong at Jun 27, 2012, 11:22:58 AM |
Version 3.5 - Old data build up issue Hi, Thanks for creating a great program. I have been using it for a week and found it to be very useful and interesting. The version I use is 3.5. During my usage, I have been importing and removing models many times. After a about a week, the Application Data\eTeks\Sweet Home 3D\work folder grew to over 4GB! Upon more careful inspection, I realized that when you delete a newly imported model, the program does not delete the associated zip file it created earlier. Also, it does not delete those files after I uninstall the program (moderate uninstall using revo uninstaller). So when I reinstall the program or re-import the model, it keeps adding more files (of the same models) to it. This can be a major issue in a long-run. By the way, if the imported models are saved in \furniture and \work folders, where are the default furniture (those that preloaded when you install the program) located? Thanks |
| Posted by Puybaret at Jun 27, 2012, 12:45:39 PM |
Re: Version 3.5 - Old data build up issue Please read this thread. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Jun 27, 2012, 12:46:42 PM |
Re: Version 3.5 - Old data build up issue The default furniture is in resource files with the program executable. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 8:41:20 AM |
