Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Problem in running SH3D in windows |
| Print at Sep 28, 2026, 10:54:36 AM | |
| Posted by Mitsaki at Jul 10, 2012, 7:41:42 PM |
Problem in running SH3D in windowsHello, first of all, I wanted to say, that I have used SH3D in MACOS and I know all the steps to make it run. I want to run it in Windows XP, 32-bit. I want to run SH3D 3.3, so I use -Djava.ext.dirs=lib;lib/windows/i386 (or no? I am not sure - nevertheless I also tried it with -Djava.ext.dirs=lib;lib/windows/x64), but I have the following error ???? 10, 2012 9:21:00 ?? javax.media.j3d.NativePipeline getSupportedOglVendorThe thing is that I wasn't sure if I could do that on 32bit, so I also tried version 2.5 where I got the same error. I installed Java JDK 5. I am quite confused about what I have to do...Is there any chance that you know what I am doing wrong? Thanks in advance Mitsaki |
| Posted by Puybaret at Jul 11, 2012, 7:29:38 AM |
Re: Problem in running SH3D in windows Try to cite full paths in -Djava.ext.dirs= instead of lib and lib/windows/i386 relative paths. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Mitsaki at Jul 11, 2012, 7:44:27 AM |
Re: Problem in running SH3D in windowsHello, thank you for the immediate answer. I did it with absolute, meaning -Djava.ext.dirs=C:\Documents\Settings\ME\workspace\SweetHome3D-3.3-src-original\lib;C:\Documents\Settings\ME\workspace\SweetHome3D-3.3-src-original\lib\windows\i386but I still get this message: ???? 11, 2012 9:36:42 ?? javax.media.j3d.NativePipeline getSupportedOglVendor |
| Posted by Mitsaki at Jul 11, 2012, 1:32:22 PM |
Re:
Problem in running SH3D in windows [SOLVED] Problem with Java 5 |
Current timezone is GMT Sep 28, 2026, 10:54:36 AM |
