Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: FurnitureLibraryEditor 1.7 on Windows 7 cannot launch |
| Print at Sep 30, 2026, 7:22:57 PM | |
| Posted by pencilart at Jul 18, 2012, 6:49:26 PM |
FurnitureLibraryEditor 1.7 on Windows 7 cannot launchI just downloaded FurnitureLibraryEditor 1.7 on my Windows 7 64 bit computer and I have Java 7 (32 bit) installed. Whenever I try to launch it, Windows says it can't open it and asks to search for a service that can open it, which is strange because this is just a local java file. SweetHome3D runs fine and so does Art Of Illusion. So, I did some looking around and I tried these (without success): C:\Users\username>java -Dcom.eteks.sweethome3d.no3D=true -jar b:\FurnitureLibraryEditor-1.7.jar the result: 'java' is not recognized as an internal or external command, operable program or batch file. Tried again: C:\Users\username>java -jar B:\FurnitureLibraryEditor-1.7.jar the result: 'java' is not recognized as an internal or external command, operable program or batch file. So, you see, Windows is not recognizing the command, java. Can you help? |
| Posted by Puybaret at Jul 19, 2012, 2:26:02 AM |
Re: FurnitureLibraryEditor 1.7 on Windows 7 cannot launch The error says that the system can't find java.exe in the PATH. Try to find where java is installed (probably in C:\Program Files\Java\jre7\bin), drag and drop the java.exe file in the command window to have its full path and then type -jar B:\FurnitureLibraryEditor-1.7.jar ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pencilart at Jul 19, 2012, 4:55:50 PM |
Re: FurnitureLibraryEditor 1.7 on Windows 7 cannot launch That's cool to be able to drag and drop the exe into the terminal window like that! Another question: Why are there 2 windows, one that looks like a terminal and the other being the desired FurnitureLibraryEditor? |
| Posted by pencilart at Jul 19, 2012, 4:57:23 PM |
Re: FurnitureLibraryEditor 1.7 on Windows 7 cannot launch I wanted to add a screenshot and I hit the wrong button, lol. Trying again: |
| Posted by pencilart at Jul 19, 2012, 5:01:31 PM |
Re: FurnitureLibraryEditor 1.7 on Windows 7 cannot launch Sorry about this, trying the screenshot with a link: ![]() |
Current timezone is GMT Sep 30, 2026, 7:22:57 PM |
