Print at Oct 15, 2026, 4:42:35 AM
Posted by Clovis at Jul 25, 2012, 10:13:53 PM
Rotate part os a projec
Is possible to rotate only a part of a project, includin some walls (their are not atached to the part that I dont want to rotate, I will atach after rotating)
Thanks
Clovis
Posted by macfrog at Jul 26, 2012, 10:52:55 PM
Re: Rotate part os a projec
Clovis,
it depends: do you mean furniture as well or just some walls and rooms?
In general, you could select all you need and copy it to the clipboad and paste this part to another empty project and rotate this part of the plan.
this can be used for walls and rooms.
hint: if you want to detach one wall from another, you just cut/paste the selected wall onto the very same spot (helpful for splitted wall segments).
the furniture has to be grouped together and rotate as on single object, later to be ungrouped of course.
macfrog
Posted by Puybaret at Jul 27, 2012, 6:38:25 AM
Maybe you could try also to use the Advanced Editing plug-in described in this document.
