Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Graphics problems... |
| Print at Oct 6, 2026, 2:05:42 PM |
| Posted by xLex at May 28, 2020, 7:32:06 AM |
Re: Graphics problems... Found a solution: 1. uninstall sh3d 2. uninstall all old java jre 3. install new java jre 9.0.4 x64 4. download and use sh3d 6.3 jar file, not exe |
| Posted by sunducth at Jul 11, 2020, 10:14:57 PM |
Re:
Graphics problems... Hi, I tried to close almost every process in windows and found this to be responsible: In my case the audio driver NahimicSvc32.exe has caused the graphical issue with the 32bit app. Closing NahimicSvc64.exe helped also for the 64bit app version. |
| Posted by Patatusina at Jul 20, 2020, 12:26:34 PM |
Re: Graphics problems... Thanks a lot, because I too by disabling NahimicSvc64.exe I solved it |
| Posted by ludjay at Jan 16, 2024, 4:53:58 PM |
Re: Graphics problems... Confirm the problem is there, but it is not necessary to disinstall or remove it, then disable the SOUND TRACKER |
| Posted by bouchetanne at Feb 25, 2024, 3:46:47 AM |
Re: Graphics problems... Bonjour, j ai un problème similaire avec un pc tout neuf zenbook15 Asus, avec Ryzen7 et AMD RADEON. Sous windows11 64 bits. J ai installé la version sh3d 7.2 et la visualisation 3d plante complement, des traits partout qui ne ressemblent à rien. Surtout pour le mobilier. Help🙏 |
| Posted by Puybaret at Feb 25, 2024, 7:05:28 PM |
Re: Graphics problems... Anne, mettez à jour le driver de votre carte graphique, c'est un problème déjà corrigé par AMD. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Enrico1972 at May 11, 2024, 9:03:50 PM |
Re: Graphics problems... Good evening, I'm using SH3D since years. Never had problems with previous revisions. Since I need the SW today, I bought last revision from Microsoft Store and it doesn't work properly. I have the same problem described by other users. My graphics drivers are already updated (NVIDIA RTX). O.S. is Windows 11: Edizione Windows 11 Pro Versione 23H2 Data installazione: 21/09/2022 Build sistema operativo 22631.3447 Esperienza Windows Feature Experience Pack 1000.22688.1000.0 Hardware is: Nome dispositivo Mostro Processore 11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz 3.60 GHz RAM installata 32,0 GB (31,8 GB utilizzabile) Tipo sistema Sistema operativo a 64 bit, processore basato su x64 Please let me know if you need further info. PS Disabling "NahimicSvc64.exe" had no effect. |
| Posted by Daniels118 at May 12, 2024, 9:10:24 AM |
Re: Graphics problems... Can you describe the problem? If you have the Pan 3D view plugin installed, maybe you should update it too to the last version; try to remove it first. |
| Posted by XalexD at May 15, 2024, 5:34:31 PM |
Re: Graphics problems... If anyone still has this problem: https://www.sweethome3d.com/faq.jsp#errorIn3DRenderingSystem get the ini file from this post in FAQ and put it into the program's folder in program files (its all there in the FAQ). This fixed it for me. |
| Posted by joaopmb at Sep 10, 2024, 2:10:57 AM |
Re: Graphics problems... I had the same problem. Disabling NahimicSvc64.exe solved it for me. dell G15 5511, windows 11, geforce rtx 3060 |
Current timezone is GMT Oct 6, 2026, 2:05:42 PM |
