Print at Sep 27, 2026, 7:06:35 AM
Posted by awiklendt at Oct 25, 2012, 9:03:17 AM
How can I select all walls (to change thickness)
Hello,
I have built my whole home and realised that I have my brick wall thickness (depth) incorrect (all internal walls are brick).
Can I select JUST the walls and change their thickness in one go? This is important because it is effecting the dimensions of various rooms and placement of various doors etc.
I have been able to select individual walls for modification, but was wondering if there was a simpler way.
Thanks.
A
Posted by Puybaret at Oct 25, 2012, 9:26:45 AM
Re: How can I select all walls (to change thickness)
The simplest way is to click in the plan to bring focus into it, choose the Edit > Select all menu item, then select Plan > Modify walls. Nevertheless, if you already place doors and windows on walls, you will have to move them a little forward and backward so they adapt their depth to the new wall thickness.
Posted by hansmex at Oct 25, 2012, 9:55:15 AM
And the fastest way is to use CTRL-A, then right-click and select Modify walls.
Posted by awiklendt at Oct 26, 2012, 11:04:21 PM
oh awesome, thanks for the quick and helpful reply, that sounds great :-) i knew there'd be a quicker way than i was using! and no worries about the windows and doors, there's less of them than the walls ;-)
Posted by eliezerhilario at Nov 13, 2022, 2:31:17 PM
Excelente. Muy Ăștil. Muchas gracias
