Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: can't open my saved file anymore |
| Print at Oct 11, 2026, 11:19:52 AM | |
| Posted by soundMax at Oct 26, 2012, 2:52:30 PM |
can't open my saved file anymore I worked on a file, saved it and now, 2 days later, while trying to open the file again, I get the error message " can not open file /user/.... fileName". other files, which I created the same day can be opened perfectly. version of SH3d: 3.7 / mac on an iMac with 10.7.5 / latest java 1.6.0_37. what can I do? thanks. |
| Posted by Puybaret at Oct 26, 2012, 2:59:14 PM |
Re: can't open my saved file anymore Since the version 3.7 was released only yesterday, you probably encountered the bug that was fixed in that version, but the correction can't recover corrupted files created with previous versions. Please send me your file. I'll try to fix it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by soundMax at Oct 26, 2012, 7:04:34 PM |
Re: can't open my saved file anymore but the file has 57 MB !!!! |
| Posted by Puybaret at Oct 26, 2012, 8:13:08 PM |
Re: can't open my saved file anymore Compress it before sending it. Don't worry for my mail box, it will accept it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Oct 26, 2012, 8:57:19 PM |
Re: can't open my saved file anymore I fixed most errors in your file but it wasn't due to the bug I fixed in version 3.7. It was probably an error that happened during a copy or a transfer, so you'd better try to find the original file if this is the case. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by soundMax at Oct 27, 2012, 1:13:09 AM |
Re: can't open my saved file anymore first of all many thanks! happy to have it working again (all the measurements... ) and this is/was the original file. I sync my iMac with my macBook through Wuala. and the file on the macBook is corrupted too. maybe something went wrong while syncing? ... |
| Posted by AlessandroDevi at Dec 9, 2012, 9:10:48 PM |
Re: can't open my saved file anymore i downloaded your beautiful program yesterday and i've a problem while open files, too. I created a new file yesterday, and today, when i tried to re-open it, i couldn't do anymore. I tried other times but it was impossible. Please help me, thanks a lot. |
| Posted by Puybaret at Dec 11, 2012, 6:05:25 PM |
Re: can't open my saved file anymore On which system are you ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AlessandroDevi at Dec 11, 2012, 10:20:36 PM |
Re: can't open my saved file anymore MAC OSX 10.6.8., on macbook pro late 2008 |
| Posted by Puybaret at Dec 12, 2012, 11:44:34 AM |
Re: can't open my saved file anymore If you transferred the file with a USB key or by email, maybe the file was altered and you should try to find the original file. If not, please send me your file, I'll try to fix it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 11, 2026, 11:19:52 AM |
