Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: White surface in 3D photo aerial view |
| Print at Oct 7, 2026, 12:23:54 AM | |
| Posted by miljenko at Nov 15, 2012, 8:40:16 AM |
White surface in 3D photo aerial view Hi, I would like to get the white surface when I create a photo from a 3d object in aerial view. Even if I choose surface to be white, it always comes out kind of silver-greyish. Thanks! |
| Posted by macfrog at Nov 25, 2012, 8:44:53 PM |
Re: White surface in 3D photo aerial view that's because the camera (you looking at your object) has to be nearly exact the same direction the light is coming from. Otherwise not enough light bounces back to the "camera", meaning white appears grey. So, if you look down vertically, make sure the "sun" (as your light source) is at high noon position in mid summer near the equator :-) this should give you "white" objects. macfrog |
Current timezone is GMT Oct 7, 2026, 12:23:54 AM |
