Print at Oct 9, 2026, 2:19:43 PM
Posted by rca19 at Nov 15, 2012, 8:15:39 PM
All Objects locked?
I have a file that I've been working on for several days with no issues. When I opened up it up today, all of the objects are locked (walls, lights, furniture, etc). I cannot move or rotate any of the objects - the only thing I can do is delete them.
I've been looking around at the various settings to see if I accidentally set a parameter, but I don't see anything. I found "Plan -> Lock Base Plan" in the menu, but that is not set.
Help - I need to continue to edit my project!
Thanks
Posted by rca19 at Nov 15, 2012, 8:35:30 PM
Re: All Objects locked?
It has something to do with grouping objects. I have two boxes that I have grouped and when I do that, all of the objects become locked. If I ungroup the group, everything works.
Posted by Puybaret at Nov 15, 2012, 8:35:58 PM
If you're using version 3.7 under Linux and grouped some pieces, it's impossible to move items with mouse in the plan. This bug is corrected and the fix will be released with the next version. Meanwhile, don't use groups or use version 3.6.
Sorry for this regression. sad
Posted by rca19 at Nov 15, 2012, 8:38:33 PM
Yep - that's it exactly. I already deleted version 3.6 and I can't seem to find a place to download it again ... where can I find a Linux download of 3.6?
Posted by Puybaret at Nov 15, 2012, 8:40:08 PM
Here:
http://sourceforge.net/projects/sweethome3d/files/SweetHome3D/SweetHome3D-3.6/
Posted by Puybaret at Nov 15, 2012, 8:43:48 PM
By the way, don't worry about downgrading your SH3D files to version 3.6. Actually, you won't lose any usable data.
Posted by rca19 at Nov 15, 2012, 8:52:18 PM
Got it ... thank you.
Posted by Puybaret at Nov 21, 2012, 9:24:33 AM
If needed please read my comment in bug report #347 too.
