Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Installation woes on MacBook Pro |
| Print at Sep 3, 2026, 1:46:26 AM |
| Posted by Puybaret at Nov 22, 2012, 6:22:17 PM |
Re: Installation woes on MacBook Pro Running the following command will help you to find where java is: sudo find / -name java -type fBe patient, this command should take a while. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jhiver at Nov 25, 2012, 7:09:11 PM |
Re: Installation woes on MacBook Pro Hello FYI /usr/bin/java is a symlink to /Applications/Xcode.app/Contents/Applications/Application Loader.app/Contents/MacOS/itms/java/bin/java Command results below, let me know what you think. MacMimi-2:~ Mimi$ sudo find / -name java -type f Password: /.MobileBackups/Computer/2012-11-21-105151/Volume/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java /Applications/Xcode.app/Contents/Applications/Application Loader.app/Contents/MacOS/itms/java/bin/java find: /dev/fd/3: Not a directory find: /dev/fd/4: Not a directory /System/Library/Java/Support/CoreDeploy.bundle/Contents/JavaAppletPlugin.plugin/Contents/Home/bin/java /Users/Mimi/Downloads/SweetHome3D-3.7-portable/jre/linux/i586/jre1.6.0_37/bin/java /Users/Mimi/Downloads/SweetHome3D-3.7-portable/jre/linux/x64/jre1.6.0_37/bin/java /usr/share/file/magic/java /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/System/Library/Java/Support/CoreDeploy.bundle/Contents/JavaAppletPlugin.plugin/Contents/Home/bin/java find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Users/Mimi/Library/Application Support/Firefox/Profiles/ymtjj956.default/adblockplus/patterns-backup1.ini: No such file or directory find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Users/Mimi/Library/Application Support/Firefox/Profiles/ymtjj956.default/adblockplus/patterns-backup4.ini: No such file or directory find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Users/Mimi/Library/Application Support/Firefox/Profiles/ymtjj956.default/adblockplus/patterns-backup2.ini: No such file or directory find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Users/Mimi/Library/Application Support/Firefox/Profiles/ymtjj956.default/adblockplus/patterns-backup3.ini: No such file or directory /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Applications/Xcode.app/Contents/Applications/Application Loader.app/Contents/MacOS/itms/java/bin/java /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/usr/share/file/magic/java find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-075548: No such file or directory /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-192444/Macintosh HD/System/Library/Java/Support/CoreDeploy.bundle/Contents/JavaAppletPlugin.plugin/Contents/Home/bin/java /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-192444/Macintosh HD/Users/Mimi/Downloads/SweetHome3D-3.7-portable/jre/linux/i586/jre1.6.0_37/bin/java /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-192444/Macintosh HD/Users/Mimi/Downloads/SweetHome3D-3.7-portable/jre/linux/x64/jre1.6.0_37/bin/java /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-192444/Macintosh HD/Applications/Xcode.app/Contents/Applications/Application Loader.app/Contents/MacOS/itms/java/bin/java nfs server localhost:/8w6P4Nds7ISDmcnIrEBiuw: not responding nfs server localhost:/8w6P4Nds7ISDmcnIrEBiuw: not responding find: fts_read: No such file or directory |
| Posted by jhiver at Nov 27, 2012, 10:04:07 AM |
Re: Installation woes on MacBook Pro Hello I managed to get it working again! I had to sudo. Then I removed all the Java Framework stuff using good old "rm -rf System/Library/Frameworks/JavaVM.framework/" Then I unpacked JavaForOSX.dmg. It contains 4 .pkg files. JavaEssentials.pkg, JavaForOSX.pkg both contain a Payload file which I have moved to /JavaEssentials.tgz, /JavaForOSX.tgz Then I dirtily did a tar zxvf of these two files while in the root folder. At this point my Java install was totally fubar, but it was good enough to "fool" the installer. Thus, I then reran the .pkg installer from the JavaForOSX .dmg file and now at last, Sweet Home 3D is working again :-) Pheeew... |
Current timezone is GMT Sep 3, 2026, 1:46:26 AM |
