Print at Sep 26, 2026, 9:16:17 AM
Posted by Remoska at Nov 19, 2012, 6:21:21 PM
Graphic Card
what kind of graphic card would you recommend?
I have an old piece ... NVIDIA GeForce GT 220
I guess, that´s the point, why is the rendering of 3D so slow.
Any tips, whats the minimum to get an optimal run.
Thanks
Posted by Puybaret at Nov 19, 2012, 8:24:50 PM
Re: Graphic Card
What quality level do you use in the photo creation tool?
Posted by Remoska at Nov 20, 2012, 10:31:19 AM
Re: Graphic Card
Always the best, sometime with light. The rendering of photos is slow, but workable. Rendering of videos with better resolution is impossible.
Posted by Puybaret at Nov 20, 2012, 2:42:01 PM
Re: Graphic Card
Keep your money then. The graphics card isn't used at the two best quality levels.
Posted by Remoska at Nov 20, 2012, 3:34:24 PM
Re: Graphic Card
Thank´s, have you any idea, why is it then so slow?
Posted by Puybaret at Nov 20, 2012, 4:14:10 PM
Re: Graphic Card
Please read the FAQ How can I speed up the rendering process in photo and video creation panes?
Posted by Remoska at Nov 21, 2012, 4:14:52 PM
Re: Graphic Card
Thank you very much.
"...install a 64 bits version of Java on your system, download the Jar executable version of Sweet Home 3D and execute the java -Xmx4096m -jar path\to\SweetHome3D-3.7.jar command for 4 GB... "
The first two steps are OK, the execution of the command should be done in the windows command line? (I did it, but not sure if something happend)
Posted by Puybaret at Nov 21, 2012, 4:30:19 PM
Re: Graphic Card
Yes, but you can launch it also with Run text field. Be sure to give the real path to SweetHome3D-3.7.jar (you can drag and drop the file in the command line window to reproduce its path).
