Print at Sep 30, 2026, 11:46:49 PM
Posted by Lumaja at Nov 29, 2012, 11:02:50 AM
Start SH 3d no file
Download you application into Ubuntu 12.04 and star using it with file Sweet home 3D.
But it stop working from the same file.
I decide to download the application again.
I uncompress to a new Directory but this time in Lib isn’t a file “Sweet Home 3D” to star the application.
What should I do?
Posted by Puybaret at Nov 30, 2012, 11:40:22 AM
Re: Start SH 3d no file
Why do you speak about "Lib"?
SweetHome3D command should be in the uncompressed directory;
Posted by Lumaja at Nov 30, 2012, 12:53:02 PM
Uncompress to SweetHome3D, created one sub directory SweetNome3D-3.7 inside this directory two other sub ones, one is kre1.6.0_37 the other is lib. I was following the instruction from SH and found the file “SweetHome 3D and after I set “allow executing file as program” in properties it worked for a while I could not find any other to start the application.
Then download the other compressed SweetHome3 and uncompressed but this one don’t have the file Sweethome 3D in its Lib sub directory.
