Print at Oct 12, 2026, 10:53:50 AM
Posted by TheJoe at Dec 8, 2012, 5:24:01 PM
a tool to scale the entire project
Maybe there is already a tool like that, but i'm not aware of it, i can't find any trace on the net. Here's how i work:
1_ import the sketch file as a background (and set dimensions)
2_ trace walls and rooms
3_ place my furniture on it
It's a very good way to have the job done, it takes few hours to finish even a floor.. but today i found out that the furniture was too big for that room, i went wrong when i set the dimensions on the bitmap file (the window is soooo narrow.. and there's no way to enlarge it.. maybe this could be improoved too).
I find no way to correct the scale i've set. And that's how i started the same project once again... wishing to be more accurate with the scale when i import a bitmap).
Posted by Puybaret at Dec 9, 2012, 12:02:26 AM
Re: a tool to scale the entire project
If you want to rescale your home you can use the Advanced Editing plug-in (documentation available here).
You can enlarge the import background wizard dialog with the borders of the dialog box. Sorry but I can't display the full screen button in this dialog box.
Posted by TheJoe at Dec 9, 2012, 2:26:47 PM
Ummhh.. i don't think the problem is in scaling the background picture, but scaling the whole project (walls, furniture, etc.). Is this possible?
Posted by Puybaret at Dec 11, 2012, 6:06:20 PM
As said previously, please use the Advanced Editing plug-in.
