Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Printing / PDF |
| Print at Oct 5, 2026, 2:45:17 PM | |
| Posted by m@ at Dec 16, 2012, 10:44:21 PM |
Printing / PDFHi There! This great open source app really rocks! But if I try to print my 2D view or even save it to a PDF, all the lines happen to be very bold. Is that normal? How can I get the lines to be as skinny as in the normal 2D view? ![]() For now, I'm using a workaround in taking screenshots and printing them, but it would be nice to have a proper solution. |
| Posted by Puybaret at Dec 17, 2012, 10:28:14 AM |
Re: Printing / PDF Did you try with a different scale? An other proper solution would be to export your plan to SVG format, or copy/paste the plan in a drawing program or the document where you want to use it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by m@ at Dec 17, 2012, 7:08:34 PM |
Re: Printing / PDF Yes I've used different scales, didn't help. But I didn't know about the copy/paste workaround; this works just fine! Thanks for the tip! |
Current timezone is GMT Oct 5, 2026, 2:45:17 PM |
