Print at Sep 30, 2026, 1:09:21 PM
Posted by rca19 at Jan 2, 2013, 12:00:50 AM
Rendering issue?
I'm having an issue rendering an image on a Mac. I'm getting some sort of rendering artifacts around a shower glass and the vanity lights. These artifacts seem to be black "circles" that I think are rendering issues. Any easy way to resolve these issues?
Thanks
Posted by Puybaret at Jan 2, 2013, 11:37:33 AM
Re: Rendering issue?
The photo renderer has still small issues that I didn't resolve that lead to that kind of problems sometimes. I think that removing the shininess on these items will solve the problem. Version 3.8 will let you reduce shininess more precisely if needed.
Posted by rca19 at Jan 2, 2013, 2:07:52 PM
Thanks for the response.
I've done some more quick testing this morning, and the issue with the shower glass is more related to the camera angle and distance from the glass. The higher the camera angle, the more black dots on the glass - an acute angle leaves the entire piece of glass black. As I change the angle to something closer to head on, the number of black dots is reduced. If I then pull the camera back slightly, the glass is rendered correctly. I have samples, but there's no easy way to get them to you through this forum.
Posted by rca19 at Jan 2, 2013, 2:11:15 PM
Here's an image the works correctly
Posted by rca19 at Jan 2, 2013, 4:47:09 PM
These images have various rendering artifacts ...
Posted by Puybaret at Jan 2, 2013, 5:01:03 PM
It looks similar to this issue. Miserably, I've no immediate solution, but I'll try to study again if there's a solution in the coming weeks.
Posted by rca19 at Jan 5, 2013, 5:11:02 PM
I was able to resolve the rendering issue with the shower glass by picking a different glass model ....
