Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: View from 2D plan? |
| Print at Oct 7, 2026, 5:29:05 AM | |
| Posted by mseward_01 at Jan 19, 2013, 4:31:57 PM |
View from 2D plan? I would like to use the 2D view for detailed plans. When I add furniture to the plan, it shows a rectangle the size of the furniture but it shows the furniture as a picture inside of the rectangle. Is there a way to show the furniture like your seeing the furniture from the top view instead of seeing the pic of it? |
| Posted by hansmex at Jan 19, 2013, 10:32:55 PM |
Re: View from 2D plan? Select Preferences --> Top view. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by F87CRUZ at Jan 20, 2013, 7:23:05 PM |
Re: View from 2D plan? HI, My in the Preferences, my Top View is lock in the Catalog Icons, how can I unluck? Thanks |
| Posted by Puybaret at Jan 20, 2013, 8:01:25 PM |
Re: View from 2D plan? If you can't choose this option, it means that the driver of your graphics card doesn't support offscreen imaging. Try to update your driver if possible. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Sajmmon at Jan 20, 2013, 8:21:17 PM |
Re: View from 2D plan? If updating drivers doesn't help try to place file: http://www.sweethome3d.com/SweetHome3D.l4j.ini in the installation directory, details of this step are described in FAQ, bullet 6, supbullet 3. From my experience it solves the problem in 99% of windows installations. |
| Posted by Puybaret at Jan 20, 2013, 11:15:15 PM |
Re: View from 2D plan? For your information, Sajmmon's tip works only under Windows. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 7, 2026, 5:29:05 AM |
