Print at Oct 2, 2026, 12:20:27 PM
Posted by [email protected] at Jan 24, 2013, 7:52:39 PM
Imported Textures: Vertical Alignment with Furnature
I'm very impressed with the package, but have a minor issue: when I texture a door with a jpg of a door and scale the image to fit, it renders displaced down the object by about 25% (so the bottom of the image wraps to the top of the door. Any thoughts?
Brian
Posted by Puybaret at Jan 24, 2013, 8:34:59 PM
Re: Imported Textures: Vertical Alignment with Furnature
Are you sure you are using the latest version 3.7? Because there was a bug about this in a previous version.
For your information, the texture is applied from the bottom to the top of the object.
Posted by [email protected] at Jan 25, 2013, 11:04:45 AM
Yes, I'm using version 3.7, Java version 1.6.0_37.
