Print at Oct 15, 2026, 1:07:36 PM
Posted by anandunadkat at Jan 28, 2013, 3:47:08 PM
Setting Angle
Hi, when i add object to my plan, the angle is not correct, so i try rotate it manually and see what angle figure i get. But when i try input that same angle into the code, and then run it, it wont be displayed with the same angle. Could anyone help me with of to set the rotation of an object correctly in java.
furniture = new HomePieceOfFurniture(catalog.getCategory(7).getPieceOfFurniture(18));
home.addPieceOfFurniture(furniture);
furniture.setAngle(90); //This wont be 90 when i run the code, it will be different!
furniture.setElevation(80);
furniture.setX(bathroomLength- furniture.getDepth()/2 + 4);
furniture.setY(new Float(bathroomLength - bathroomLength/1.19));
Posted by Puybaret at Jan 28, 2013, 3:54:45 PM
Re: Setting Angle
The angle is in radians.
Posted by anandunadkat at Jan 28, 2013, 4:16:34 PM
Re: Setting Angle
Thank you for your help, and what about X and Y to set an object.
Posted by Puybaret at Jan 28, 2013, 6:11:41 PM
Re: Setting Angle
All dimensions in the model are in centimeters
