Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can i do final render with the transparent walls from "modify 3D view" included? |
| Print at Oct 7, 2026, 1:46:00 PM | |
| Posted by mistergreen at Feb 12, 2013, 4:42:16 AM |
Can i do final render with the transparent walls from "modify 3D view" included? After reading about 60 pages of posts (no prob i learned lots anyway), i encountered lots of discussion on transparency. Not one mention though of the first thing i noticed when i did a render. The transparency setting from "modify 3D view" did not translate to the render. Is this a possibility and i just can't figure out how to do it? |
| Posted by Puybaret at Feb 12, 2013, 8:02:23 AM |
Re: Can i do final render with the transparent walls from "modify 3D view" included? Sorry, walls transparency isn't taken into account at the two best quality levels of the photo creation tool. A workaround could be to export to OBJ format your home then reimport it as a piece of furniture in a new project. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Feb 12, 2013, 11:31:02 AM |
Re: Can i do final render with the transparent walls from "modify 3D view" included? Trevor, If you want (a) transparent wall(s), you could apply a transparent texture to both sides of your wall(s). Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 7, 2026, 1:46:00 PM |
