Print at Sep 29, 2026, 6:36:37 AM
Posted by Brasileiro at Feb 28, 2013, 3:12:54 PM
applause   Light doubt
hey guys, how can i add a source of light to a lamp ? in the new models ? e.g the menu with the light power % all of my new lamps doesnt have it... can i add it ? or only manual ajust the spot light on the bulb ? thanks wink
Posted by Puybaret at Feb 28, 2013, 3:20:55 PM
Re: Light doubt
Yes you can, but if it has no effect, keep in mind that light can't go through an opaque surface.
Posted by Brasileiro at Feb 28, 2013, 3:34:30 PM
Re: Light doubt
so how can i add the light power to a new lamp ?
i didnt found the option when i imported them
Posted by hansmex at Feb 28, 2013, 3:40:53 PM
Re: Light doubt
Guilherme,
There still are a few issues with light.
1 - Light cannot be exported or imported.
If you have a lamp without light, you cannot add a light to it, then export and import it, in the hope that you then have a lamp with light. The light doesn't survive this process.
2 - Mirrors do not reflect light
If you look at an object in a mirror, you will be able to see that object.
If that object is in the dark, you will (obviously) not be able to see that object. You cannot use a mirror to throw light on your object, because the mirror doesn't reflect the light.
Posted by Brasileiro at Feb 28, 2013, 3:53:47 PM
Re: Light doubt
Guilherme,
thank you Hans, so the best option is to add the light source that already have in the library and try to put it closer to the bulb ? i dont know if you understood because my english is not good, but thanks very much for the help guys, sorry for the stupid questions but i wanna do it right u know...
Posted by RobertBurke22 at Mar 3, 2013, 12:22:45 AM
Re: Light doubt
I've had Sweet Home 3D for a few years, and since the introduction of lights, I've been pretty happy. When I came across a light that did not produce light, I just added a light source near it. It gives the same effect.
Posted by Brasileiro at Mar 4, 2013, 12:07:57 PM
Re: Light doubt
yea Robert, this is what im doing too!
