Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Printing problem |
| Print at Sep 27, 2026, 5:20:27 PM | |
| Posted by dherfindahl at Mar 1, 2013, 10:25:08 PM |
Printing problem Is it possible to print the plan at 1:120 and have the grid lines show? How? |
| Posted by hansmex at Mar 1, 2013, 11:48:44 PM |
Re: Printing problem David, You cannot print the grid from within the program, but there is a workaround: 1 - Create a new layer (Plan --> Add level) and make sure it is the lowest layer (if that is what you need) 2 - Draw long "lines" by placing very long, thin boxes; make sure to place the boxes correctly by editing their coordinates. To print the plan: 1 - File --> Page setup --> Scale 1:120 2 - Set the page size 3 - Print the plan to your printer (File --> Print), or as a PDF (File --> Print to PDF) Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by forestgreen at Jul 5, 2014, 9:46:33 PM |
Re: Printing problem I had the same question / problem today and I solved it by creating a grid in a vector drawing program (I used the free software Inkscape) and exporting that grid as a bitmap. Then I imported this bitmap into Sweet Home 3D and scaled it properly so that the grid line distance became exactly 100 cm. Looks good in the printout. |
Current timezone is GMT Sep 27, 2026, 5:20:27 PM |
