Print at Oct 1, 2026, 12:32:30 AM
Posted by elbesweet at Mar 2, 2013, 10:32:39 PM
Changing the angel of the curve stair from down to up
It’s some weeks, I try to draw the plan of my “castle”. There I have to install a corner stairs. But the 90° angle of the curve stair shall be above; not below! How will it go?
Thank you for short answer and friendly greetings from Bleckede by the Elbe - and for all, who do not understand my english – here is my german text
elbesweet
ich versuche seit einigen Wochen den Grundriss meines „Schlosses“ zu zeichnen. Ich muss eine Ecktreppe einbauen. Aber der 90° Winkel der Curve Treppe soll oben sein; nicht unten!
Wie geht das?
Danke fuer kurze Antwort und freundliche Gruesse aus Bleckede an der Elbe
elbesweet
Posted by Puybaret at Mar 3, 2013, 7:51:38 AM
Re: Changing the angel of the curve stair from down to up
Maybe you'll find the staircase you look for in Trimble 3D Warehouse?
Note that Sweet Home 3D furniture import wizard supports DAE/Collada format but not SKP/SketchUp format. So if the model you prefer is available only in SKP/SketchUp format, you'll have to convert it to DAE/Collada format by choosing File > Export > 3D Model... out of the menu in the free version of SketchUp.
If you want the imported staircase to automatically create a hole in the floor of the upper floor, you'll have to check the Staircase option at the third step of the furniture import wizard. If the default hole doesn't match what you want, the easiest way is to draw a room at the upper floor that will show the hole you want.
