Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: day or night image |
| Print at Sep 30, 2026, 4:08:38 AM | |
| Posted by mnadeem at Mar 6, 2013, 11:34:31 PM |
day or night imageHi i like to know how can i add day or night image or pic in background in plan , can any one please give intructions how to do that , i have create a home project but unable to add day and night situations |
| Posted by mnadeem at Mar 7, 2013, 12:01:57 AM |
Re: day or night image Hi i like to know how can i add day or night image or pic in background in plan , can any one please give intructions how to do that , i have create a home project but unable to add day and night situations i have also not found ? 3D View -> Modify -> Sky texture -> Import |
| Posted by mnadeem at Mar 9, 2013, 10:35:39 AM |
text on wallssh3d,,, how can i write some text on walls and move it to any position, Do i have too make a photo print and then add it , i need some advise , thanks in regards |
| Posted by hansmex at Mar 9, 2013, 12:55:18 PM |
Re: text on walls Make an image of your text. Import the image as a texture... ... and apply it to a thin box. Place the flat box on front of your wall (as if it were a painting). H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by mnadeem at Mar 11, 2013, 8:56:50 AM |
Re: text on wallsHi thanks for the supper answer , but how can i make a image + png or jpg and with what software , is there guide second i have try to import some textures but it is too difficult for me |
| Posted by hansmex at Mar 11, 2013, 9:12:16 AM |
Re: text on walls 1 - Use a graphics program like the Gimp or 2 - Use a text processor to write out your text, then make a screenshot, and crop the image with a program like Irfanview H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by mnadeem at Mar 11, 2013, 11:03:12 AM |
Re: text on wallsthanks in regards , but my ? is that how can i write some text or add pic or paste on the wall in any side and also can rotate with it . need info or advise how to make it in 3d |
| Posted by mnadeem at Mar 17, 2013, 9:11:18 AM |
Re: text on wallsHI thanks i have done as you says it works but my ? is i want to make a wall then on it want to write some text , then this wall can be used in SH§D and rotate any side or make it big or small like i do in others textures and furniture |
| Posted by mnadeem at Mar 17, 2013, 9:14:55 AM |
Re: text on walls sorry write text or paste on the wall in 3d effects |
| Posted by hansmex at Mar 17, 2013, 10:46:43 AM |
Re: text on walls Maybe this will help? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by mnadeem at Apr 21, 2013, 1:27:19 AM |
Re: text on walls Hi lately very busy . i still can not write text on wall . or i think i am not giving more information what i am trying to say, so i have a wall create in sh3d then give some colors , some people hanged there image or pictures , but simply want to write on it .then want to copy as a new furniture then export to obj format , so then i can use it many time as i wish , i hope not asking too much |
| Posted by Puybaret at Apr 21, 2013, 12:25:37 PM |
Re: text on walls There's no direct way to write a text on the wall. As Hans partly suggested, a workaround is to create an image containing that text (eventually with a transparent background), import that image in the program as a texture, and apply that texture on a thin box. Of course, if you have to do that many times, it will become tedious and Sweet Home 3D might not be the right solution for you. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mnadeem at Apr 21, 2013, 12:33:55 PM |
Re: text on walls So back again . ?: If i have a pic or jpg or any type format how can i add to my furniture or as a object 3d still not understanding how this program works , in furniture import wizard only you can chose between obj,dae 3ds,lws,zip. but no jpg file , is there any one tell me what should i do thanks in regards |
| Posted by mnadeem at Apr 21, 2013, 12:43:14 PM |
Re: text on walls Ok if so then tell me how can i add frame made by any picture or photo as , or my photo taken by camera to hanged in living room or bedroom |
| Posted by mnadeem at Apr 21, 2013, 12:50:12 PM |
Re: text on walls HI there must be a way to add 2D models import like 3D models import |
| Posted by Puybaret at Apr 21, 2013, 1:00:38 PM |
Re: text on walls As said previously, import the image containing your text in the program as a texture, and apply that texture on a thin box (found in Miscellaneous category). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mnadeem at Apr 21, 2013, 2:05:03 PM |
Re: text on walls hi as you say ,import the image containing your text in the program as a texture, and apply that texture on a thin box,, how is there any pdf file to understand , i have import jpg file but not found any where , its vanished |
Current timezone is GMT Sep 30, 2026, 4:08:38 AM |
