Print at Sep 28, 2026, 11:00:23 PM
Posted by robinpecha at Mar 14, 2013, 10:36:07 AM
Walls from prefabricated modules
Hi, it is possible to import part of the walls?
I want to build a wooden houses from the prefabricated modules.
Module sizes are 1 x 3 m.
http://i46.tinypic.com/156amab.jpg
Thanks for the info.
Posted by hansmex at Mar 14, 2013, 6:34:22 PM
Re: Walls from prefabricated modules
You can easily build these pieces using SH3D. Use Export as OBJ, then Import as furniture.
Posted by robinpecha at Mar 14, 2013, 6:54:01 PM
Thank you for the reply.
But perhaps it is not possible to create a wall so that the composed of several modules?
Posted by hansmex at Mar 14, 2013, 8:43:44 PM
If you use imported models, they behave as "furniture".
So, they make look like a wall, but they do not behave like wall.
Example: you cannot insert doors or windows in an imported wall segment. And you cannot give the inside of the imported wall segment a different colour or texture as the outside. That has to be done when you design the wall segments.
On the other hand, you can place wall segments next to, and on top of each other, and you will not see the difference.
