Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Using Sweet Home 3D in Eclipse |
| Print at Sep 27, 2026, 2:51:17 AM |
| Posted by Gforce85 at Mar 27, 2013, 6:31:41 PM |
Re: Using Sweet Home 3D in Eclipse By the way my java runtime library is in the following path: C:\Program Files (x86)\Java\jre7\bin Maybe I Should add the java 3d dll files in this 'bin' folder and point to this folder from the VM option like this ?: -Djava.library.path=C:\Program Files (x86)\Java\jre7\bin |
| Posted by binadnsh77 at Apr 1, 2013, 10:22:22 AM |
Re: Using Sweet Home 3D in Eclipse I think it does not work in i386 window systems. It works fine in Linux-32 bit and windows 64 bit. I have tried it. |
| Posted by Puybaret at Apr 1, 2013, 10:32:16 AM |
Re: Using Sweet Home 3D in Eclipse I think Gforce85 and you mixed so much things in the DLLs and the PATH of your Windows computer that it's too difficult to help you without being in front of it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gforce85 at Apr 1, 2013, 8:13:30 PM |
Re: Using Sweet Home 3D in Eclipse I think Gforce85 and you mixed so much things in the DLLs and the PATH of your Windows computer that it's too difficult to help you without being in front of it. It works now with the windows 64 bit version!: My installation dir is: D:\Open Source\Sweet home 3D 27-3-2013\SweetHome3D-4.0-src And in eclipse at the run configuration menu I have this in the VM arguments: -Djava.ext.dirs=lib/windows/x64;lib |
| Posted by binadnsh77 at Apr 9, 2013, 11:29:15 AM |
Re: Using Sweet Home 3D in Eclipse I installed Java3D in my Windows 32 bit system and then I was able to run the sweethome3d from eclipse. Since I had installed the Java3D there was no need to pass the VM arguments. |
Current timezone is GMT Sep 27, 2026, 2:51:17 AM |
