Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Dimensioning |
| Print at Sep 28, 2026, 7:43:11 PM | |
| Posted by jonnies at May 4, 2013, 10:07:27 PM |
Dimensioning Is there a way to get dimensions to "stick" to objects? For example, I have two walls that are 10' apart, as shown by a dimension line. I want them to be 9' apart, but if I drag a wall, the dimension line doesn't change. Is there a way to have dynamic dimensions that change as you drag an object? I thought I saw this behavior at one time, but I can't reproduce it. For that matter, whenever I want to move an object, say in the x or y dimension, is there a way to specify how far to move it other than to invoke the Modify box and type in the x or y coordinates of the location (for furniture) or start and end points (for a wall)? When dragging an object, it would be nice if there was a dynamic display of the current location relative to the original location. |
| Posted by Puybaret at May 6, 2013, 4:48:52 PM |
Re: Dimensioning Is there a way to get dimensions to "stick" to objects? Sorry, it's not possible.Relative moves are not possible too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 7:43:11 PM |
