Print at Sep 26, 2026, 7:45:30 AM
Posted by okh at May 24, 2013, 12:43:04 PM
Background panaorama
Doing some maintenance with the help of SH3D, I couldn't help myself trying to add some background to the model photo. As I didn't have an actual panorama, I used www.virtual-globe.info (better resolution than Google Earth, at least Norwegian data-set).
Link to photo on Flickr
PS - Prodess: add transparency to the model photo and copy into background image (using Gimp)
Posted by Puybaret at May 24, 2013, 2:38:13 PM
Re: Background panaorama
Nice idea, but why did you have to add transparency to your model photo?
Posted by okh at May 24, 2013, 3:41:07 PM
I deleted the sky/ground from sh3d photo to see the background. Then I made my slanting terrain model (green at level 0) semi-transparent to blend in.
I see now that I seem to have added transparency to the chalet itself too, but that was unintended :-)
The chalet is an "eagle's nest" and the vista is just like this. Virtual globe makes it easy, as it supports geo-co-ordinates and angle of view in a hyperlink (thinking plug-in linking from the compass in sh3d, but maybe not really useful).
Posted by okh at May 24, 2013, 3:58:01 PM
Re: Background panaorama - linking to vista
Consider a house outside Sallanches, Haute-Savoie - the link would look like this to provide a realistic backdrop.
http://www.norgei3d.no/VirtualGlobeStarter.ph...00000001243&libs=Xj3D
Or - Verbier (Chemin D'Amon)
Just as examples. But as it is probably only useful in montainous areas, it is probably not worth a plug-in...
