Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: sweet home 3d do not run |
| Print at Oct 3, 2026, 11:02:58 PM | |
| Posted by tonicosta at May 24, 2013, 5:17:56 PM |
sweet home 3d do not run Hi, I cannot run sweet home 3d. I have ubuntu 13.04. Some day when I was try to update sweet home 3d for version 4.0 it stopped to run. I uninstalled it and reinstalled version 3.7 and keep to not run. I can no longer use in the sweet home 3d. |
| Posted by hansmex at May 24, 2013, 7:32:03 PM |
Re: sweet home 3d do not run Uninstall Java IceTea, and install Sun Java. That will (most probably) solve your problem. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by tonicosta at May 31, 2013, 3:32:32 PM |
Re: sweet home 3d do not run How can I install Sun Java? |
| Posted by hansmex at May 31, 2013, 4:28:49 PM |
Re: sweet home 3d do not run I'm not familiar with Ubuntu 13.04, using 12.04 myself. Go to Ubuntu Software Center and search for Java. Uninstall whatever is installed, be it OpenJDK or IceTea. Then follow these instructions. I haven't tried them, but they look OK to me. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at May 31, 2013, 6:41:42 PM |
Re: sweet home 3d do not run You shouldn't have to install any Java version if you use the installer proposed for download on SourceForge.net. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 11:02:58 PM |
