Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D View goes blank, how to "refresh" |
| Print at Oct 13, 2026, 1:24:37 AM | |
| Posted by John37 at Jun 9, 2013, 10:42:55 PM |
3D View goes blank, how to "refresh" The 3D view displayed in a separate window is blank when I switch back to SH3D after using other programs. Is there a simple way of "refreshing" the 3D view when I return to SH3D so the image returns? |
| Posted by Puybaret at Jun 9, 2013, 10:55:27 PM |
Re: 3D View goes blank, how to "refresh" How did you install Sweet Home 3D? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by John37 at Jun 9, 2013, 11:40:43 PM |
Re: 3D View goes blank, how to "refresh" I downloaded the Sweet Home 3D installer |
| Posted by Puybaret at Jun 10, 2013, 12:02:15 AM |
Re: 3D View goes blank, how to "refresh" Too bad, I thought this bug happens only under Java 7 with Java Web Start. Please try to resize Sweet Home 3D window or move the separators around the 3D view, it should refresh the 3D view. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by John37 at Jun 19, 2013, 10:46:22 PM |
Re: 3D View goes blank, how to "refresh" Thanks for the suggestion. I tried it already, but it doesn't work. I usually have to close the 3D view so it displays in the main window and then select Display in separate window again. This often takes about 2 minutes. Sometimes it is so unresponsive that I have the Exist the program and re-launch. Anyway it's not a big problem I just thought there may be a simple solution. |
| Posted by c0d3z3r0 at Dec 26, 2024, 10:40:13 PM |
Re: 3D View goes blank, how to "refresh" I had a very similiar problem: when opening any properties windows for furniture, the 3D view would go blank. I fixed this by killing this 3D view refresh code: diff --git a/SweetHome3D/src/com/eteks/sweethome3d/j3d/Component3DManager.java b/SweetHome3D/src/com/eteks/sweethome3d/j3d/Component3DManager.java |
Current timezone is GMT Oct 13, 2026, 1:24:37 AM |
