Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Roof with transparent material |
| Print at Oct 8, 2026, 6:04:41 PM | |
| Posted by mau67 at Jun 12, 2013, 9:41:27 AM |
Roof with transparent material Dear, thanks for this spectacular software. Just a question: I need to made a roof (over patio)with wood structure and transparent (glass) roofing. How can I do it ? Thanks in advance. Maurizio |
| Posted by hansmex at Jun 12, 2013, 11:35:52 AM |
Re: Roof with transparent material Maurizio, Look here. Files with "transp" in the filename are boxes with transparency in different colours. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by mau67 at Jun 12, 2013, 1:48:44 PM |
Re: Roof with transparent material Dear Hans thx thx thx , the transparent box was perfect. But I've a little thing again..(sorry...): I need to put the wood structure (made from cube) and the trasp roofing, tilt down from wall to the garden. Can you help me ? Thanks Maurizio |
| Posted by hal9000 at Jun 12, 2013, 2:34:29 PM |
Re: Roof with transparent material Take a look at this tutorial: http://www.sweethome3d.com/slopingCeilingGuide.pdf In rough, you have to compose (or re-import) the object vertically, give the inclination as a rotation over Z axis (which is the only allowed in the plan editing), then export the rotated object and re-import it again rotating it so it's horizontal again. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
| Posted by mau67 at Jun 12, 2013, 5:16:53 PM |
Re: Roof with transparent material Hans....I will be crazy :-( I'm not able to tilt the obj....ever and ever flat. I've read the tutorial but I'dont found the right tip. What can I do ? Thank in advance, I'm sorry for the "torture". Maurizio |
| Posted by mau67 at Jun 12, 2013, 5:17:53 PM |
Re: Roof with transparent material Ops ! Thanks to Hal :-) |
| Posted by Puybaret at Jun 12, 2013, 5:41:24 PM |
Re: Roof with transparent material I'm not able to tilt the obj....ever and ever flat. I hope the text Hold the Shift key down while clicking on an arrow to rotate the model at smaller steps that is shown at the second step of the import wizard would have been helpful enough. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mau67 at Jun 18, 2013, 4:21:24 PM |
Re: Roof with transparent material Dear, the way is not easy but...that's ok. Thanks to all |
| Posted by Puybaret at Jun 18, 2013, 5:04:02 PM |
Re: Roof with transparent material Rotation in the 3D space around 3 axes is never easy in all 3D software! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 8, 2026, 6:04:41 PM |
