Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create photo missing options? |
| Print at Oct 2, 2026, 8:41:53 PM | |
| Posted by jdetmold at Aug 12, 2013, 11:27:47 PM |
Create photo missing options?I started using sweet home about a week ago and was playing with the create photo feature and creating panoramic images of my rooms. now i have build a house and the panoramic option is gone as well as all the lighting controls instead my options are resolution, proportions (including 3d view and several # ratios), and quality nothing else :( how did i lose this great feature and more importantly how can i get it back? |
| Posted by hal9000 at Aug 13, 2013, 4:02:35 PM |
Re: Create photo missing options? Did you use the same SH3D version both times? On older SH3D versions you could use the photo creation plugin, which gave many more options. On newer SH3D versions some options have disappeared or are controlled by parameters on other places, and in addition the old plugin doesn't work anymore. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
| Posted by hansmex at Aug 13, 2013, 4:23:55 PM |
Re: Create photo missing options? @hal9000 - Angelo The PhotoCreation plugin is obsolete. All its functions have been incorporated into SH3D at least since version 3.7. The plugin is NOT compatible with newer versions and will not work. @jdetmold - Jeff You need to provide more information if you want any hope of a solution. - What OS are you using? - What version of SH3D are you using? Which version number, installed or webstart? - Did you make any changes to your computer? Updates, or so? - Did you transfer the file from another computer? If so, areboth files the same? - Did you make changes to the file? Maybe add (faulty) models? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by hal9000 at Aug 13, 2013, 4:57:37 PM |
Re: Create photo missing options? @hal9000 - Angelo The PhotoCreation plugin is obsolete. All its functions have been incorporated into SH3D at least since version 3.7. The plugin is NOT compatible with newer versions and will not work. I know, Hans, that's what I said. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Oct 2, 2026, 8:41:53 PM |
