Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Placing furniture in more than one level. |
| Print at Sep 27, 2026, 4:00:43 AM | |
| Posted by MarkW at Aug 30, 2013, 4:54:29 AM |
Placing furniture in more than one level. Having placed furniture in level 0, I placed two items in level 1 successfully. After that when I try to add more furniture into level 1 it is rejected and the display jumps back to level 0. I have tried all sorts of remedies like closing the program and reopening, and completely rebuilding from scratch but whatever I do I can not place furniture on more than one level. Am I missing something? |
| Posted by MarkW at Aug 30, 2013, 10:07:12 AM |
Re: Placing furniture in more than one level. I found the answer in the user's guide. You have to right click and "add to home". I was just dragging and dropping which worked fine in one level. Should have read the guide before I started I suppose, but the app is so intuitive that I didn't think I would need to. Love it! |
| Posted by Puybaret at Aug 30, 2013, 10:57:10 AM |
Re: Placing furniture in more than one level. Adding furniture by drag and drop should work whether you use levels or not. Simply select first the tab of the level to which you want to add furniture. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 4:00:43 AM |
