Print at Sep 26, 2026, 11:10:56 PM
Posted by pabloyepes at Oct 3, 2013, 3:17:41 PM
Problems because of low memory
I think I am pushing the limits of SweetHome. I have a 22,000 sq ft building with 3 floors and roofs. When tyring to take a photo with very high resolution, SW complains that memory is not enough after a while. I wonder if that problem could be solved by recompiling the program with a higher memory allocation. Would that be something "simple" to do?
Thank you
Posted by Puybaret at Oct 3, 2013, 3:22:39 PM
Re: Problems because of low memory
There are simpler solutions. Look at the FAQ How can I adjust the memory used by Sweet Home 3D? and eventually this message.
Posted by pabloyepes at Oct 3, 2013, 6:39:54 PM
Thanks a lot. That did it. Now also the rendering seems to run faster
