Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: White sky |
| Print at Sep 28, 2026, 11:33:59 AM | |
| Posted by pabloyepes at Oct 3, 2013, 6:50:38 PM |
White sky I am using version 4.1 on Linux. When I render an image of the whole building with an aerial view in level 4, the sky always comes out white. In the 3D properties I tried to use a texture of various skies, and using just a dark blue color. In all cases, on the rendering the sky looks white. I have also changed the brightness, but it does not change the result. Any ideas? |
| Posted by Puybaret at Oct 5, 2013, 7:35:09 AM |
Re: White sky I guess it's white because you view a part of the generated sky in direction of the sun. As stated in the help: If you selected a color for the sky in the 3D view pane or if the current mode is Aerial view, a sky image computed according to the hour of the day is used for the rendering of the sky. If you chose a texture for the sky, that texture will always be used in Virtual visit mode whatever the selected hour. So try to use a texture image for the sky.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pabloyepes at Oct 12, 2013, 11:11:23 AM |
Re: White sky I also tried with a texture, but it still shows a white sky. Any other ideas? Thank you |
Current timezone is GMT Sep 28, 2026, 11:33:59 AM |
