Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Newbie: How do I draw a room to match a wall with an arc? |
| Print at Oct 4, 2026, 6:21:00 PM | |
| Posted by carlos_spork at Oct 25, 2013, 11:50:11 AM |
Newbie: How do I draw a room to match a wall with an arc? Hello, I can't find a way to draw the room (floor) inside a room that has a wall with a 90-degree arc. Can someone help me with this? Thank you so much! |
| Posted by hansmex at Oct 25, 2013, 11:54:28 AM |
Re: Newbie: How do I draw a room to match a wall with an arc? Carlos, To draw a room, choose the Room button, then double-click inside your room. If that doesn´t work, the walls of your room aren´t closed. Make sure that all walls are connected, or edit the X,Y coordinates so that the end of one wall has the same coordinates as the start of the next wall. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by carlos_spork at Oct 26, 2013, 2:39:13 PM |
Re: Newbie: How do I draw a room to match a wall with an arc? Thank you so much, Hans! I didn't know about the double-click feature to create a room. In my case, the walls weren't closed anyway. I also noticed that, in the end, it's just a matter of "connecting the dots", so I just added additional dots to make it look a bit better when zooming-in in the 3D-view. Again, thank you! |
| Posted by carlos_spork at Oct 26, 2013, 3:43:09 PM |
Re: Newbie: How do I draw a room to match a wall with an arc? By the way, Hans, this is an example of what I was trying to achieve: Gravel access-path |
Current timezone is GMT Oct 4, 2026, 6:21:00 PM |
