Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: stairs rail |
| Print at Oct 2, 2026, 11:28:25 AM | |
| Posted by Miriamk at Nov 14, 2013, 6:41:50 PM |
stairs rail Hi I am quite new here and have no much experience. I was trying everything in order to create the stairs with the angles i wanted. I couldn't find any aproperiate model and therefore I created stairs with "box" stair by stair.... now I desperetely need a rail. and preferbly made out of glass. How can I create an adjusted rail? |
| Posted by okh at Nov 14, 2013, 8:33:28 PM |
Re: stairs rail ...desperetely need a rail. and preferbly made out of glass. How can I create an adjusted rail? Compliments on doing a box stairs. Good idea. To your glass rail question, there is no easy answer (that I can think of). But maybe you could use something like this (stair_rail_glass.zip)? Probably needs some stretching and patching. ok |
| Posted by okh at Nov 14, 2013, 9:17:16 PM |
Re: stairs rail BTW: you could also put a thin, sloping wall next to your stairs (modify start and end height). But it wouldn't solve your glass and rail problem. As you need to fit it to a specially angled staircase, you may have to look into using 3d model software to get the measures and angles right. |
Current timezone is GMT Oct 2, 2026, 11:28:25 AM |
