Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: terrace, hanged wall |
| Print at Sep 26, 2026, 4:57:01 PM | |
| Posted by kempher at Dec 16, 2013, 7:53:49 AM |
terrace, hanged wall Hi, i am a newbie in this forum, may somebody can help me. How to create a hanged wall in terrace up side, because i try to make it with the wall, not feature to change elevation which is can make the wall move higher, i need solution an thank you ![]() |
| Posted by okh at Dec 16, 2013, 11:49:05 AM |
Re: terrace, hanged wall Provided I understand your question, how about: Either create a new level where you want the wall to be elevated, or use an invisible box or opening to remove the lower part of the wall. ok |
| Posted by kempher at Dec 17, 2013, 1:56:25 PM |
Re: terrace, hanged wall Thank's man, i'll try to find 3d model of invisible box, recommended extention file of invisible box may .obj or....? |
| Posted by okh at Dec 17, 2013, 2:37:17 PM |
Re: terrace, hanged wall Creating an elevated level (even if it is just for that wall) would be my preferred solution. For a box, you can use this (zipped .obj - drag drop into plan) - just make sure you import it as a door/window so it cuts a hole in your wall. ok |
Current timezone is GMT Sep 26, 2026, 4:57:01 PM |
