Print at Sep 30, 2026, 12:33:43 AM
Posted by jz77f at Dec 16, 2013, 8:38:39 AM
Working version for Ubuntu 13.04?
I used to run an old version of Sweethome3d on Ubuntu 10.04 without a problem. Then I installed Ubuntu 13.04 and the latest version of Sweethome3d (v.4.2) and it no longer works sad . It crashed when I opened Preferences, then I used a fix found in this Forum which fixed the Preferences problem, but the program crashed unexpectedly at other time.
Can anyone suggest a version of Sweethome3d that works under Ubuntu 13.04 without any workarounds and tweaking, please? It doesn't have to have fancy new features. ..Something that every user likes the most: Download, double-click to install, and run it ! smile
Thanks.
jz77f
Posted by hansmex at Dec 16, 2013, 9:01:08 AM
Re: Working version for Ubuntu 13.04?
The trick that works really well for Ubuntu 12.04 is as follows:
- uninstall IcedTea Java and OpenJDK through the Software Center;
- install Oracle Sun Java (look here)
Posted by jz77f at Dec 20, 2013, 1:31:50 PM
Hello Hans,
thank you very much for your suggestion but I have tried that before and it doesn't work for Ubuntu 13.04. Opening Preferences still causes a crash.
Sweethome3D v.4.2a worked flawlessly on my Ubuntu 12.04 without installing Oracle Java JDK (..OpenJDK 6 and 7 and IcedTea Java installed). Under Ubuntu 13.04 no version seems to be working (I tried version 4.0, 4.1, 4.2) with or without the Oracle Java exercise. I hate thinking of reinstalling Ubuntu 12.04 as it would take a couple of days sad ..
My advice to anyone using Ubuntu 12.04 LTS: Don't replace it with Ubuntu 13.04, if you want to keep using Sweethome3D!
jz77f
Posted by jz77f at Dec 25, 2013, 5:38:28 PM
Finally I solved the problem by creating another partition for Ubuntu 12.04. Works OK now smile (but requires rebooting sad ).
