Print at Sep 30, 2026, 11:04:01 AM
Posted by dorgan at Jan 23, 2014, 11:56:03 PM
Level 0 walls appear in every level
Love this software, which I just started using. Obviously I am new to it, but suddenly: 1) The walls from Level 0 are visible (in black not grey) in every level; 2) When I create a new level they appear as if by magic overlaid on the grey walls from the lower lever; 3) I am unable to edit or delete them. No doubt I'm doing something embarrassingly silly, but would appreciate guidance so I don't have to rebuild the 4 floor building from scratch again.
Posted by okh at Jan 24, 2014, 8:05:24 AM
Re: Level 0 walls appear in every level
1) & 2) Your level 0 walls are probably higher than the level itself. Edit walls (select, right-click, modify walls) and/or level (click top tab) properties.
3) In the top left corner of the 2D view, there is a padlock to lock and un-lock the base-plan. Un-locking should let you edit walls.
