Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Save Problem |
| Print at Sep 2, 2026, 6:46:13 AM | |
| Posted by KellyJesse at Jan 30, 2014, 6:51:58 PM |
Save Problem Hey, I seem to be having troubles saving my project when I add certain pictures as the material for a picture frame. I'm using the online version. I get the errors- RecorderException: Can't save home java.io.IOException: Server returned HTTP response code: 500 I'm not much of a tec guy so I have no clue what this means... Thanks for the help! |
| Posted by Puybaret at Jan 30, 2014, 8:26:54 PM |
Re: Save Problem It could be because one of your two projects reached the size limit authorized on the server, i.e. 3 MB. Sorry, but I won't increase that value. If you need to import more textures, you'll have to export your project and use the installer version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KellyJesse at Jan 31, 2014, 1:47:01 AM |
Re: Save Problem Awesome. thank you so much for the quick response! |
| Posted by HFfan at Mar 9, 2014, 12:42:20 AM |
Re: Save Problem Hi! I might be running into the same problem, that I cannot save my home due to it is too large in the online version. If I export the sh3d file and install the software, can I open it with the installed version? I do not want to turn off my computer as I do not want to lose 6-7 hours of work :) I really like the progem!!! Thanks for it! |
| Posted by Puybaret at Mar 9, 2014, 10:20:23 AM |
Re: Save Problem If I export the sh3d file and install the software, can I open it with the installed version? Yes. While keeping your browser open, you can test it: download Sweet Home 3D installer, run the installer, open with it the file exported from the online version, then close the webpage of the online version.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 2, 2026, 6:46:13 AM |
