Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Copy&Paste between files |
| Print at Sep 30, 2026, 5:43:46 AM | |
| Posted by hfrmobile at Feb 16, 2014, 8:32:24 AM |
Copy&Paste between files I am in the situation where I editing two .sh3d files. Sometimes I need to copy some furniture from one file to the other (so that I not have to adjust size, position, color etc. manually), but this seems not to be supported for the moment? |
| Posted by okh at Feb 16, 2014, 9:39:34 PM |
Re: Copy&Paste between files Copy / paste between files should work, at least it works perfectly for me under Win 8.1, Java 1.6.0_45 / 64 bit. So if it doesn't work for you, it might help eTeks if you supply info about your environment. ok |
| Posted by hfrmobile at Feb 17, 2014, 9:15:09 PM |
Re: Copy&Paste between files Thank you for your response! Tried it on another machine and it worked. Sometimes the Paste menu item is grayed even the clipboard contains valid data. In that case just click somewhere on the plan and the menu item will be enabled. One minor issue which would be worth an improvement: When pasting the object that it is not pasted into the current location/room. So you have to scroll a bit. But even this is better than not having the Copy&Paste between files :) |
Current timezone is GMT Sep 30, 2026, 5:43:46 AM |
