Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: exterior-door-03.zip |
| Print at Sep 26, 2026, 11:52:31 PM | |
| Posted by hfrmobile at Feb 16, 2014, 7:51:34 PM |
exterior-door-03.zip exterior-door-03.zip door imported as "door" but not rendered as door in 2D view. In 3D view it works like expected. |
| Posted by okh at Feb 16, 2014, 9:35:31 PM |
Re: exterior-door-03.zip If you import an object, checking the Door/Window checkbox, it will adjust to the walls and cut the correct opening. It will also behave like a door in the 2D view, but if you want the 2D view to display the door opening etc, you need to use a door which also supplies these properties (like the ones in the pre-installed collection). The file you mention, is an .obj file which does not support such extra features (wall thickness, door opening/angle, etc). ok PS. It is possible to add the extra features, but you must do it yourself by imporint the model into a library and edit the PluginFurnitureCatalog.properties. This thread will explain the properties you need to add: http://www.sweethome3d.com/support/forum/view...d,2006_lastpage,yes#17627 |
| Posted by hfrmobile at Feb 17, 2014, 9:45:09 PM |
Re: exterior-door-03.zip Thanks for the hint! Tried:
Exists there a 3D model designer which as easy to use as SH3D? |
| Posted by okh at Feb 18, 2014, 8:27:55 AM |
Re: exterior-door-03.zip Exists there a 3D model designer which as easy to use as SH3D? Short answer, no :-( - see this thread and lots of other threads. AoI, Blender, Sketchup, Wings 3D - and then obviously commercial ones - matter of preference. All 3D modelling software will require some patience in the learning process. Furniture Library Editor: Just a "converter".. The Furniture Library Editor is a furniture library editor it deals with libraries of models: converts, scales, lets you add cut-outs etc. but not designer.Note that for the door swing you wish to display in the 2D win, you need only an editor - PluginFurnitureCatalog.properties is a (zipped) plain vanilla ascii file specifying properties of library elements. ok |
Current timezone is GMT Sep 26, 2026, 11:52:31 PM |
