Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Making a slanting parapet and joining two of them at the corner |
| Print at Sep 24, 2026, 5:52:46 PM | |
| Posted by iqbaljawaid138 at Feb 28, 2014, 11:24:50 PM |
Making a slanting parapet and joining two of them at the corner Hi, I am trying to make a slanting parapet wall that joins at the corner and apply texture to it. Made the parapet by using a sloping wall and using thiness as length and length as thickness. This makes the texture appear on the wrong side. Any help is appreciable. If I could upload an image, would have been gr8. Thanks in advance, Jawaid |
| Posted by hansmex at Mar 1, 2014, 3:48:52 AM |
Re: Making a slanting parapet and joining two of them at the corner Jawaid, A picture would be appreciated if you want an answer. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by iqbaljawaid138 at Mar 1, 2014, 9:02:15 PM |
Re: Making a slanting parapet and joining two of them at the corner Thank You Mr. Hamsmex for the responce. Being a newbee to this site I can't see direct image upload. However here is the link. For the first link (nw.jpg)I want the Edges to be Smooth as shown in the second link (example.jpg). https://www.dropbox.com/s/y2gg8jzivwq55ji/nw.jpg https://www.dropbox.com/s/bh5ckoud5e85lz2/Example.jpg https://www.dropbox.com/s/vxwa12ttobv5qlw/Mumtywall.jpg In the 3rd link, I wanted to bend the groove in the wall, to curve out on the top. Thank you , Jawaid |
| Posted by hansmex at Mar 2, 2014, 11:31:53 AM |
Re: Making a slanting parapet and joining two of them at the corner Jawaid, This thread explains how you can share images. This file shows a workaround for your parapet: parapet workaround If this image shows more or less what you want to do, then you should use another program. SH3D is designed for interior decorating, not for professional architectural design. You will need a "real" 3D design program like Sketchup . Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by iqbaljawaid138 at Mar 3, 2014, 7:36:13 AM |
Re: Making a slanting parapet and joining two of them at the corner Thanks Hans, Your Idea worked. Had to make slight adjustments but nice. Will upload the .obj and the picture. By the way I am not a professional. Its my home that I am trying to design. Regards, Jawaid |
Current timezone is GMT Sep 24, 2026, 5:52:46 PM |
