Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Can't open Sweet Home 4.3 on my Mac OS 10.9.2 |
| Print at Sep 2, 2026, 6:24:02 AM | |
| Posted by arcgee at Mar 3, 2014, 9:23:26 PM |
Can't open Sweet Home 4.3 on my Mac OS 10.9.2I installed Sweet Home 4.2. It installed but would not open. I upgraded Java as a thread suggested. Then I installed Sweet Home 4.3. It won't open. Help!! ![]() |
| Posted by Puybaret at Mar 4, 2014, 2:26:15 PM |
Re: Can't open Sweet Home 4.3 on my Mac OS 10.9.2 Please give more details. What do you mean by "it won't open"? Don't you see the splash screen of Sweet Home 3D when you launch the program? Can't you open an existing document? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by peterwood at Mar 13, 2014, 11:52:36 PM |
Re: Can't open Sweet Home 4.3 on my Mac OS 10.9.2 Same here. Sweet Home 3D v. 4.3 on Mac OS X 10.9. If you double click the icon it just does nothing. In a terminal If I run: $ /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D [JavaAppLauncher] Requested [1.5*], launching in [1.7] instead. JavaVM: Failed to load JVM: /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/bundle/Libraries/libserver.dylib JavaVM: Failed to load JVM: /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/bundle/Libraries/libserver.dylib JavaVM FATAL: Failed to load the jvm library. [JavaAppLauncher Error] JNI_CreateJavaVM() failed, error: -1 $ I have a file created with version 4.2 on Mac OS 10.8 called Home-2ndFloor.sh3d In a terminal if I run: $ open Home-2ndFloor.sh3d LSOpenURLsWithRole() failed with error -10810 for the file Home-2ndFloor.sh3d I installed the version that is bundled with Java. Any idea what may be wrong? How to fix it? Thanks, -- Peter |
| Posted by Puybaret at Mar 14, 2014, 8:57:03 AM |
Re: Can't open Sweet Home 4.3 on my Mac OS 10.9.2 Install Apple Java. If you run the program by double clicking on Sweet Home 3D icon instead of using Terminal, it should propose to install it automatically. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by peterwood at Mar 14, 2014, 7:05:50 PM |
Re: Can't open Sweet Home 4.3 on my Mac OS 10.9.2 I have java: $ java -version java version "1.7.0_51" Java(TM) SE Runtime Environment (build 1.7.0_51-b13) Java HotSpot(TM) 64-Bit Server VM (build 24.51-b03, mixed mode) $ Double clicking on the icon does nothing. I downloaded SweetHome3D-4.3.jar and this works: java -Xmx2048m -jar SweetHome3D-4.3.jar So, I have a working solution. I just wished the icon will work too. Thanks for the great product. |
| Posted by Puybaret at Mar 15, 2014, 10:51:46 AM |
Re: Can't open Sweet Home 4.3 on my Mac OS 10.9.2 Did you install Apple Java 6? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 2, 2026, 6:24:02 AM |
